APPCRASH on niviswnd.dll
I am using a 32-bit executable (built with LabView 2010) on a win7 - 64 bits.
There is a step in the program taht causes APPCRASH with the following description:
Problem Event Name:                        APPCRASH
Application Name:                             ----------.exe
Application Version:                           5.0.3.0
Application Timestamp:                     4d2fa0d5
Fault Module Name:                          niviswnd.dll
Fault Module Version:                        13.0.0.49156
Fault Module Timestamp:                  51c64b21
Exception Code:                                  c0000005
Exception Offset:                                000124a9
OS Version:                                          6.1.7601.2.1.0.256.48
Locale ID:                                             1033
Additional Information 1:                  0a9e
Additional Information 2:                  0a9e372d3b4ad19135b953a78882e789
Additional Information 3:                  0a9e
Additional Information 4:                  0a9e372d3b4ad19135b953a78882e789
I did not figure out for the moment wich vi exactly causes the crash.
Do you have any idea about that?
Thank you in advance for your help.
(2,778 Views)
Hello again,
I tried to compile my application an another computer and with LabVIEW 2013. I still get a crash at the same step but it is not called the same.
(see attached LV log)
Does this help someone to understand what's happening ?
(2,762 Views)
I have a previous version of my application that wotks perfectly.
I have tried to compile again this version, then I got the error.
Then I completely uninstall and re-intall LabVIEW and all NI modules on my computer.
I still get the same error.
If I uninstall the "bugged" version I can install agian the runable executable on a computer.
What is annoying is that I have a usable version that I now can't modify.
Does anyone have an idea ?
Thank oyu for your help.
(2,718 Views)
