Assistance with JSONtext - From JSON Text
So, I am dabbling in the world of JSON using the JSONtext VIs from JDP Science. In my very simple example, I have a first name, last name, and a date of birth which I think I have formatted correctly. When I run my VI, I can't seem to extract the data via my simple JSON string and end up with an error:
Since this is my first time working with JSON, I don't know exactly what the problem is. I'd appreciate the assistance of what to look for.
The VI that is attached should be down converted to v18.
Message 1 of 8
(771 Views)
You need quotes around the date.  Even then, I am getting a different error (Not a supported timestamp format).  I'll have to dig in order to get to the bottom of that one.
GCentral
Message 2 of 8
(757 Views)
Accepted by topic author Eric1977
Date/Time stamp must be a string in ISO8601 format
Santhosh
Soliton Technologies
Message 3 of 8
(746 Views)
Hmmm, I wonder why the date that gets returned from the date time constant returns 8:00:00 PM? I am in the Eastern Time Zone.
Message 4 of 8
(735 Views)
Eastern Daylight Time (EDT) = UTC-4:00 => 12-4 = 8
GCentral
Message 5 of 8
(733 Views)
Santo - how did you know that the JSON dates need to be in the ISO format you linked? That link you posted appears to go to Wikipedia. Is there a website of whitepaper that speaks to that?
Perhaps it is in there and I just skipped over it.
Eric
Message 6 of 8
(655 Views)
The way I figured it out was a mix of experiment and experience but not through documentation.
From using JSON extensively in Python, typically, the ISO format is used. I tried the "Anything to JSON" VI with Timestamp data and the JSON text obtained showed the familiar ISO format with T and Z characters.
https://docs.jsonata.org/date-time
Santhosh
Message 7 of 8
(645 Views)
If you look inside the 'To JSON text' and 'From JSON text' functions, you will find calls to a dependent JDP Timestamp Library that describes the string formatting as RFC 3339.
JSON has no native timestamp data type.
Now is the right time to use %^<%Y-%m-%dT%H:%M:%S%3uZ>T
If you don't hate time zones, you're not a real programmer.
"You are what you don't automate"
Inplaceness is synonymous with insidiousness
Message 8 of 8
(637 Views)
