Blurry icon text
When you look in your C:\Windows\Fonts folder, do you see one called "Small Fonts Regular"?
Redhawk
Test Engineer at Moog Inc.
Saying "Thanks that fixed it" or "Thanks that answers my question" and not giving a Kudo or Marked Solution, is like telling your waiter they did a great job and not leaving a tip. Please, tip your waiters.
Message 21 of 30
(3,560 Views)
In some instances in the past, I actually "wrote text" pixel by pixel using the drawing tool. That's of course slow. 😄
Message 22 of 30
(3,552 Views)
"When you look in your C:\Windows\Fonts folder, do you see one called "Small Fonts Regular"?
I think we are on the right track. I have found small fonts regular in the fonts folder but if I try deleting it I see the following popup:
The properties shows:
For me this suggests that Arial.ttf is installed under the name of Small fonts regular. I dont even know if this is possible, but for sure I can't delete / uninstall this font as windows says its a protected system font.
If I go to the fonts folder directly then there is a smalle.fon which is identical to the one I have downloaded earlier so I assume that this file is OK.
I dont know whats going on, but maybe some of you have came across a similar issue earlier.
Message 23 of 30
(3,524 Views)
https://forums.ni.com/t5/LabVIEW/Small-Fonts-missing/td-p/3720897
Qestit Systems
Certified-LabVIEW-Developer
Message 24 of 30
(3,515 Views)
"Small fonts" is installed already. I have downloaded the zip file though, installed but no change. People in the other forums had the issue that the font was missing from their PC. The problem I have is that I have the font but it seems that its not the right one.
Another thing that I have found is that if I open the font settings and type "small" than it returns nothing. (but if I type eg. Arial then it show that).
Also could somebody check what happens with the icon text if in the icon editor the font is changed to Arial. (on win10 with Cleartype turned on)
thx
Message 25 of 30
(3,507 Views)
I think windows fonts are only .ttf and small font is some bitmap if memory serves. I don't have small fonts in the control panel list either. This sounds familiar. I messed with some similar thing several years ago.
So, this file should be in your c:\windows\fonts folder. (you can unpack, r-click and choose Install)
There might be some ini-file that needs editing so the system doesn't replace the font.
Qestit Systems
Message 26 of 30
(3,496 Views)
Accepted by 1984
Finally I got it... it was a localization thing. In the control panel > region > Administrative > Language for non Unicode programs must be set to English. I'm unsure if the previous steps (eg: reinstalling small fonts, reinstalling MS office etc) have done anything. Could be a combination of everything, but if you read this topic the first time then try changing this fist.
Man... this was a hard one to figure out 😛
Message 27 of 30
(2,333 Views)
That's not true.
I changed non-Unicode settings to non-English 2 years ago.  I have never had problem with icon font before or after the non-Unicode change.  I always use small font for the icon.
No problem in Win7 Pro and Win 10 Pro 64 bit.
George Zou
Message 28 of 30
(2,281 Views)
I like the way that you skip the foreplay and just go straight into "not true". Thats always a sign of a goal oriented professional!
Well, most likely not all the localizations mess up the fonts like in my case, but for mine it did. If you dont have a problem with blurred icons, good for you, nothing to be changed.
But if you have, then just try changing it to English as it solved my problem.
Message 29 of 30
(2,277 Views)
The icon editor doesn't work well with unicode, not for small font.  I can't use Russian or Chinese.  But no blur.
George Zou
Message 30 of 30
(2,263 Views)
