Can LV display multicolour fonts?
Can LabVIEW display multicolour bitmap fonts? I want to draw some text with a glow effect. If there is some way of doing this via normal text indicators, this would be favourite.
(2,554 Views)
You should be able to. Through Property node --> text --> select you can select part of the text and set color, repeat as needed.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,533 Views)
Hi Yamaeda,
the OP (probably) talks about this...
(2,521 Views)
Thanks guys. The Windows 8.1 stuff is interesting but I'm assuming this is not yet supported by LabVIEW?
What I actually need is for individual characters to contain multiple colours. I'm happy to use bitmap fonts if that's what it takes.
Any ideas?
(2,511 Views)
If a single character is to use several color i assume you'll have to render a picture and show that.
/Y
Qestit Systems
(2,498 Views)
