Comparing LabVIEW OOP Class Hierarchies
Hello all,
The Question
Does anyone know of a tool for comparing LabVIEW class hierarchies?  (Like "Compare VI Hierarchies" for .lvclass hiearchies?)
For Example
Let's say I have foo.lvclass in two projects and I want to compare the two instances and their respective members.  Does one instance have methods that the other doesn't?  Does a method or private data differ?
Why?
I have several applications with dozens of classes, many of which should be interchangable, and I want to quickly determine which classes are the latest, perhaps consolidating some common base code.
I thought about posting this as a suggestion on the Idea Exchange, but I wasn't sure if I'm just not seeing functionality that's already there.
Thanks very much,
Jim
(3,337 Views)
Hi all,
I'll take that as a "no."  Smiley LOL
If anyone is ever interested, here's my correlating Idea Exchange post.
Thanks for looking!
Jim
(3,280 Views)
Accepted by topic author Mr._Jim
Hi Jim,
There does not appear to be any way to do this. The closest functionality I could find was to use the Compare VIs/Compare VI Hierarchies to compare the .ctl files for two classes. The LabVIEW Help topic documents how to do this:
http://zone.ni.com/reference/en-XX/help/371361L-01/lvhowto/comparing_vis/
However, this does not really achieve the functionality you are looking for. Thank you for posting this idea to the Idea Exchange!
Catherine B.
Applications Engineer
(3,269 Views)
Good morning Catherine,
Thanks for the reply!
Kind regards,
Jim
(3,258 Views)
