Control When Tip Strip Appears
I am having a problem trying to control when the Tip Strip appears.  I would only like the Tip Strip to appear only when the LED is in a blinking state and at no other time.  I attached my attempt at this. Thanks for your help.
(2,466 Views)
Accepted by MCHammer
you can wire empty string constant to tip strip property in false case.
(2,465 Views)
That did the trick.  Thanks.
(2,460 Views)
