Crash LabVIEW with VI Property Node
If you have a new VI that's never been saved (i.e. path is "Not a Path"), then this can cause LabVIEW to crash:
(763 Views)
I could not reproduce the crash in the latest 2023 Q3
(743 Views)
When an output of a property node is not wired, the code that would get the value is skipped.
Try wiring the output "Library" to something.
(728 Views)
Duh. Of course. 🙄
But it still doesn't crash for me.
(716 Views)
No crash in 2021 either. That's the only two versions I have available right now.
(705 Views)
The problem is occurring in a VI that's being called by the configuration VI of an Express VI.
Outside of that circumstance, I also cannot recreate the problem.
The VI that's trying to get the library reference is in context "NI.LV.Express".  The VI that's being referred to is in context "My Computer".  (But when I make test code that uses those contexts, I still don't get a crash.  (For some reason, it only happens when an Express VI's configuration is running.)
I observe the problem in LV 2019, 2020, & 2021.
(648 Views)
