Create labview program
And how would you run this this test if you weren't using LabVIEW?  If you were running any unnamed, miscellaneous program?  Or if you were doing this test manually?
Answer those questions before you worry about LabVIEW.
Message 11 of 13
(323 Views)
danil33 wrote:
thanks for your reply. I have to measure the path loss in a transmission in different frequency range. Is it possible to do without DAQ devices?
Hi Danil33
Thanks for your file.
Message 12 of 13
(316 Views)
Thanks for your suggestion. I think i'm getting started in wrong direction.
Message 13 of 13
(314 Views)
