07-22-2012 11:54 PM
And how would you run this this test if you weren't using LabVIEW? If you were running any unnamed, miscellaneous program? Or if you were doing this test manually?
Answer those questions before you worry about LabVIEW.
07-23-2012 12:52 AM
danil33 wrote:
thanks for your reply. I have to measure the path loss in a transmission in different frequency range. Is it possible to do without DAQ devices?
Hi Danil33
Thanks for your file.
07-23-2012 12:54 AM
Thanks for your suggestion. I think i'm getting started in wrong direction.
