DAQmx current measurement using NI PCI 6251
Hi ,
i'm using NI PCI 6251 to measure voltage using 8 Analog input ( measure with resistance Ohm's Law)
i'm measuring the active and sleeping current so i need some VI examples on how can i get the two currents , this is the circuit.
Circuit.jpgAny help please .
(2,699 Views)
Use a DAQmx Scale to have the current calculated for you by the driver.  Just look in the Example Finder for examples.
GCentral
(2,647 Views)
