DAQmx stop task.vi crashes
I am trying to use a USB-6003 DAQ board to acquire an analog voltage signal using Labview 2022Q3 (Full edition). I am able to read data from the device using the attached vi but whenever I stop the acquisition in the while loop the program crashes at the 'DAQmx stop task.vi'. This happens every time I run the program. I also get the error message in the attached .png file describing the error as:
Exception: Access violation (0xC0000005) at EIP=0x00007FFC30D7503D.
I have tried running one of the DAQmx example programs (Digital - SW-Timed Input.vi) to acquire data from one of the digital input lines on the USB-6003 and saw the same thing happen. The vi would grab the data correctly but crash when I stopped the while loop and it tried to stop the task.
Any advice?
Stuart
(353 Views)
It could be related to the USB hub power settings.  Go into the device manager and disable the "Allow the computer to turn off this device to save power" for all of the USB hubs.
GCentral
(339 Views)
Thanks for the response.
I changed the power setting s for the USB hubs but get the same result. The vi still crashes when it tries to stop the DAQmx task.
Stuart
(320 Views)
