DSC 8.5.1 incompatible with products already installed
I am trying to install DSC 8.5.1 on a WinXP system with LabVIEW 8.5.1 and 8.6.1 already installed. When I try to install the DSC module, the installer tells me the module will not be installed because "This feature is incompatible with products already installed on the computer." Can anyone tell me which products are incompatible with the DSC module?
Thanks.
Chuck
(2,906 Views)
Hello Chuck,
I couldn’t find any incompatibilities regarding the DSC module with other versions of LabVIEW or any other software on the readme file nor other documentations. I have, however, seen cases where installing a version of DSC that is older than a later version of LabVIEW installed might cause problems. Try uninstalling LabVIEW 8.6.1 and re-try to install DSC 8.5.1. If that fails, try uninstalling all NI Software and then install LabVIEW 8.5.1, then DSC 8.5.1. If that is successful, I would go ahead and install LabVIEW 8.6.1.
Daniel REDS
RF Systems Engineer
Help us grow.
If a post solves your question, mark it as The Solution.
If a post helps, give Kudos to it.
(2,894 Views)
Thanks Daniel,
Well, installing in that order worked, except that the DSC module menu item does not show up in the block diagram pop-up menu in LabVIEW 8.6.1. I've tried to do a repair to the DSC module after installing 8.6.1, but no luck. It shows up in 8.5.1, but not 8.6.1. Any ideas?
Thanks.
Chuck
(2,881 Views)
Accepted by topic author Chuck60148
Hello Chuck,
I am glad that it worked. Seems that it was LabVIEW 8.6.1 the incompatible product the installer was complaining about. In order to install the DSC module for LabVIEW 8.6.1, you would need to install DSC 8.6.1, as the module and the LabVIEW version need to match.
Daniel REDS
RF Systems Engineer
Help us grow.
(2,873 Views)
Thanks. I didn't realize there was a DSC 8.6.1. I'll have to dig that one up.
(2,866 Views)
