Error 1 occurred at Armijo rule stepsize reduction failed to reduce function value within maxiters
I am trying to use the unconstrained optimization VI to fit a measured Spectrum. However, on each call of the Vi I get the error:
      Possible reason(s):
      LabVIEW:  An input parameter is invalid. For example if the input is a path, the path might contain a character not allowed by the OS such as ? or  @.
     NI-488:  Command requires GPIB Controller to be Controller in Charge.
Does anybody know what I am doing wrong and how I can fix it?
The VI for the Armijo rule stepsize reduction can be found here:
<labviewPath>\vi.lib\gmath\NumericalOptimization\qn_armijo rule stepsize reduction.vi
In the current implementation, the Spectrum is fit to a rectangular Spectrum. Can this be the cause for the error?
I have attached the VIs I am using. They are written in LabVIEW 2010.
(3,086 Views)
Hi TKlostermann,
could you be a bit more precize about your error? I can't get it.
At which exact step do you get the error? Could you give us a project with some data in which we can reproduce the error?
(3,039 Views)
Accepted by TKlostermann
Thank you Marc67 for your quick reply, but I found the error.
It was rather stupid, I used a bad starting vector for the Unconstrained Optimization VI, which had too low values.
(3,009 Views)
