Error -1074360293 occurred at IMAQdx Get Image.vi
I have question on Vision Acquisition system;  the VI is able to "run" with serval minutes, and  there is an error that appears:
"Error -1074360293 occurred at IMAQdx Get Image.vi
NI-IMAQdx: (Hex 0xBFF6901B) Timeout"
I able to view the ip camera and acquire from it within MAX. Also, able to test on Vision Acquisition. please look at below picture. But no any image show on vi during vi run.
Any helps are much appreciated. Thanks a lot.
(5,073 Views)
Hi VickyTong,
There are a few steps you can try such as turning off your firewall to see if this is interfering with your acquisition. Also here is a forum post which addresses the same issue:
http://forums.ni.com/t5/Machine-Vision/IMAQdx-Timeout-Error-0xBFF6901B/m-p/583335#M14945
Paolo F.
Applications Engineer
(5,033 Views)
