05-18-2014 07:35 AM
I have question on Vision Acquisition system; the VI is able to "run" with serval minutes, and there is an error that appears:
"Error -1074360293 occurred at IMAQdx Get Image.vi
NI-IMAQdx: (Hex 0xBFF6901B) Timeout"
I able to view the ip camera and acquire from it within MAX. Also, able to test on Vision Acquisition. please look at below picture. But no any image show on vi during vi run.
Any helps are much appreciated. Thanks a lot.
05-19-2014 03:49 PM
Hi VickyTong,
There are a few steps you can try such as turning off your firewall to see if this is interfering with your acquisition. Also here is a forum post which addresses the same issue:
http://forums.ni.com/t5/Machine-Vision/IMAQdx-Timeout-Error-0xBFF6901B/m-p/583335#M14945
