Error 201381
I'm trying to build a simple low pass filter. When not connected only the +-15 V and Grnd are connected to a bare board I don't get the error but once they are connected to the OpAmp, I get the error. Any idea what I should do?
(5,983 Views)
Accepted by ajustwoods
Error -201381 occurred at an unidentified location
Possible reason(s):
One or more connections to external power rails are drawing too much power. The operation has been aborted to prevent the device from using too much power.
Remove the connection(s) to the external power rails and restart your task.
What DAQ device are you using?  It sounds like you are trying to draw more power than the device is able to provide.  How are you powering the op amp?  You shouldn't be using the DAQ device outputs, but using a dedicated power supply.
(5,968 Views)
It turns out I had connections backwards, exhaustion I guess. Thank you though.
(5,955 Views)
