Excel application reference is "0" when program running
Hi All,
I am using ActiveX for working with excel and application was working in couple month ago. Now when I am trying to use it looks there is missing reference but even when I try to use any way to set reference in RUN mode there is not populated. Where could be a problem?
Thank you. BR
(755 Views)
Accepted by topic author JosefN
You may want to read this prior forum thread to see if that problem and solution applies in your case.
Dave
David Boyd
Sr. Test Engineer
Abbott Labs
(lapsed) Certified LabVIEW Developer
(713 Views)
Thank you. It solves that issue.
(648 Views)
