Filtering Audio Signals based on Amplitude Threshold in LabVIEW
I am working on a project where I acquire audio signals from a microphone in LabVIEW. The signals contain various frequencies and amplitudes. However, I need to filter the signals based on their amplitudes. Specifically, I want to neglect any signals with amplitudes exceeding 1V for example.
I am seeking guidance on how to implement this filtering process efficiently in LabVIEW. I am open to suggestions on using either LabVIEW's built-in functions or custom coding approaches to achieve this task.
Any insights, suggestions, or example implementations would be greatly appreciated. Thank you in advance for your help!
(471 Views)
My first thought from your description is you are trying to increase the "Noise-to-Signal" ratio (whereas most LabVIEW users would rather increase the "Signal-to-Noise" ratio).  You can certainly do this, for example, by computing the spectrum of your signal, finding finding the frequency region with the largest amplitude, and designing a "band-reject" or "ban-stop" filter to remove those frequencies, but are you sure this is what you want?
P.S. -- can you post a "picture" (I generally dislike pictures in the Forum) of a signal where you want to remove the large-amplitude part?  I must be missing something, but can't figure out what ...
(422 Views)
