Format two 2d arrays to Excel
Hello all,
Just a quick, probably simple question. Have been reading trough the forum, but couldn't find the answer.
I have two 2d arrays which I want to save to en excel file. Till now I have simply implemented this by using write to measurement file function without any problem. Unfortunately the two 2d arrays are just next to each other, no empty cells in between to divide the two arrays. As well i'd like to put a header above each 2d array. Just something like below:
Voltages:
5 4 2 8 3
7 0 2 5 1
6 8 2 3 3
Amperes:
1 2 3 5 2
7 9 4 2 5
2 1 1 6 3
Any help, ideas or example vi's are welcome!
WHW
Message 1 of 9
(3,947 Views)
Message 2 of 9
(3,924 Views)
Thanks for reply Artem.SPb
No I dont.
I was wondering if it is possible to fix this by putting everything in one big 2d array and inserting an empty row in between. And of course two rows with the header for each array.
Does anybody know a trick to create 'empty' rows? I know its not the nicest way of programming but yea... Smiley Frustrated
WHW
Message 3 of 9
(3,916 Views)
Accepted by HEWI
Hi HEWI,
Yes, that's possible. And it would fix your issue…
Yes.
Spoiler
Create an array of empty strings. As I would create spreadsheet files (aka CSV files aka formatted text files) I would convert those arrays to string arrays anyway. And putting row/column headers into you need to use strings also!
Message 4 of 9
(3,904 Views)
Btw I'm open for any other ideas to put the two 2d arrays separated and with a header in an excel sheet, but if possible i'd like to stick to the write to measurement function since it's simple.
WHW
Message 5 of 9
(3,902 Views)
Hi HEWI,
Use several WriteToSpreadsheetFile function calls…
If something is "simple" it may not allow for more complicated tasks… 😄
Message 6 of 9
(3,899 Views)
Thanks for your reply GerdW,
Thats excactly what I was thinking of.
But then the question how to combine those, headers, empty string and arrays, i cant just combine those things since they are different dimensions.
WHW
Message 7 of 9
(3,891 Views)
Hi Hewi,
when you have a 2D array of values you surely want to use an 1D array of headers (for rows and columns). Think about it…
Message 8 of 9
(3,878 Views)
Okay, have my big 2d array of strings with headers, data and empty rows now!
Last question is how to convert the array of strings to dynamic data so that I can wire the array to the write to measurement file function.
Best regards and thanks in advance,
WHW
Message 9 of 9
(3,849 Views)
