HOW CAN I SEND A TABLE TO A TEXT FILE
      I have a table with a lot of values , and i need to transfer this table to a text file (.txt) , without lose the position
of this values in that table .Someone can help me with this?
Thx Smiley Happy
Message 1 of 8
(5,402 Views)
Thx Smiley Happy
Hi dunno wha...,
in this case you should write your data into a *.csv file. You can open it with excel and you still have your table.
Mike
Message 2 of 8
(5,388 Views)
Accepted by topic author faelnpaiva
Or you can use Write to Spreadsheet File.vi
~Jonathan
LV 8.2/8.5/8.6 - WinXP
Message 3 of 8
(5,377 Views)
Hi again , now i have another problem ...
 the values of table is tranfering ok , but the header isnt going togheter ..
Do u know how i append the headers of table in the file ?
thx ^^
Message 4 of 8
(5,347 Views)
You can write your header ahead of time, then append your table later on.
Cory K
Message 5 of 8
(5,335 Views)
What component is that ?
Has this component in labview 6.0 ?
Message 6 of 8
(5,305 Views)
Yes it is there is LabVIEW6.0 with a different icon. SO, just read the Vi label in file I/O function.
Message 7 of 8
(5,292 Views)
There is some conflicting and incorrect information here. First, to get the column headers of a table, you use a property node and the property 'Column Header Strings[]'. This is a string array and you can append it to the 2D string array that is the table contents.
In 6.0, the Write to Spreadsheet File was not able to write a string array. However, there are instructions on the block diagram that describe what needs to be modified. After making the modifications, save the VI with a new name and in a new location.  I know for a fact that the modified VI has been posted to the forum. You can do a search but the actual modifications should take less time.
Message 8 of 8
(5,279 Views)
