Help! How to read CSV file and use as input?
I want to read CSV file and plot it using Python.
How can I read CSV file and use it as Python node input?
like this csv file
How can I read it and use X, Y values as input to Python node?
Message 1 of 9
(2,075 Views)
like this csv file
That's 3 pythons in 1 request. Why not just use python? pandas.read_csv()
https://pandas.pydata.org/docs/reference/api/pandas.read_csv.html
then use the plot() method
https://pandas.pydata.org/docs/reference/api/pandas.DataFrame.plot.html
Wow, look at that, no Labview involved.
______________________________________________________________
Have a pleasant day and be sure to learn Python for success and prosperity.
Message 2 of 9
(2,067 Views)
Yeah I know how to do it with Python.
I am just trying to learn how to use LabView and integrate with python..
Message 3 of 9
(2,062 Views)
ok I see, you need to use a python node, have you tried that?
Message 4 of 9
(2,059 Views)
Yes I am trying to use the python node.
As far as I know, I can read the csv file using this Read Delimited. However, I don't know how I can use its output to use as input to Python node. Sorry, I am a very newbie to Labview..
Message 5 of 9
(2,053 Views)
Accepted by wzh0053@auburn.edu
Try something like this, you will need to add some things to this, like your paths, to make it work but its a starting point
Message 6 of 9
(2,038 Views)
Thank you so much!
I was trying to find this symbol, but I couldn't find same one.
I believe it is the array subset. How can I build that one?
Thank you again
Message 7 of 9
(2,031 Views)
Thank you so much!
Thank you again
Right click on the orange wire and then navigate as shown here:
Message 8 of 9
(1,975 Views)
That icon is actually the Index Array function that changes its image to match the array wired into it and is expandable for multiple outputs.  Just hover over the bottom edge to expand it.
Michael Munroe, CLD, CTD, MCP
Automate 1M+ VI Search, Sort and Edit operations with Property Inspector 5.0, now with a new Interactive Window Manager!
Now supports full project automation using one-click custom macros or CLI.
Message 9 of 9
(1,823 Views)
