How can I close the error window
I am new in LabVIEW and trying to learn by running some basic function. But then this error occurred and only way to remove it is by closing the software. Is there any solution to close this window?
(1,173 Views)
That is a dialog from the Simple Error Handler.  You just have to press the "Continue" button to close it.
GCentral
(1,166 Views)
If I click continue, is shows next error, and it keeps going to the infinite.
(1,145 Views)
Accepted by mub.re
At least from the snippet, you should not be getting infinite error messages unless you're using the "Run Continuously" button instead of the Run button
Never ever use the "Run Continuously" button (you can do it once you have a strong understanding of how things work)
Santhosh
Soliton Technologies
(1,133 Views)
Thank you for the solution
(1,092 Views)
