How can I convert data in string into all available data types in Labview?
The parsed data from XML Parser gives me all the data and specifications in the string format. I want to convert these data into various (all available)  data types. Is there a possible solution for it?
Message 1 of 16
(8,165 Views)
Can you specify a particular data type that you are not able to?
Message 2 of 16
(8,158 Views)
Message 3 of 16
(8,144 Views)
Thank you for the suggestion.
But I need something that can change e.g. String: ''10'' in to I-32 ''10''. Type cast gives me the value related to string that is ''1952804352'' in I-32 indicator. I don't know how to use that value to get ''10''.
Message 4 of 16
(8,105 Views)
Accepted by R_Chintan
Use decimal string to number
19831i8A73FEB3D492D745
Message 5 of 16
(8,097 Views)
Specifically, you can define a constant with a different datatype on the input on the lower left if you need a different datatype (e.g. U8, I64, DBL, etc) Are all your values integers or do you also need to scan fractional numbers? In this case, you should use "fract/exp string to number" instead.
Message 6 of 16
(8,092 Views)
Yes you are right.
I can change integers only. All integeer types.
But I want all possible datatypes in input so that I can change them to appropriate output.(U8, 16, 32, Double, string, etc)
Message 7 of 16
(8,077 Views)
Do you still have a question or are you just repeating my answer in slightly different words?
(The input is always string, and for the output you need to decide on the most appropriate datatype when designing the program. I am curious why you would specify string as a possible output. Since you already have a string, no code is needed for this, right?)
Message 8 of 16
(8,065 Views)
The default conversion is I32. Right click properties and choose the required conversion required.
19841iB4CEFFC45C3D6CF0
Message 9 of 16
(8,056 Views)
I suspect the poster is looking for something like a "dynamic" Scan From String function. One where you enter the format string programmatically, and the outputs "automagically" change datatype at run-time. Such a beast, of course, does not exist. If this is the case, I would suggest using a polymorphic VI instead (one that would use a numeric constant to select the specific type of conversion so you'd get the "appropriate" datatype for the output).
Message 10 of 16
(8,041 Views)
