How do you creat this in Labview
@Kyle97330 wrote:
"NI MAX" isn't a package.  It should have installed automatically with LabVIEW.
I don't think MAX comes with LabVIEW, but definately with DAQmx.
GCentral
Message 11 of 13
(687 Views)
I have Labview 2014. Even after installing from the link, it still doesn't show on Measure & automation explorer
Message 12 of 13
(686 Views)
Now you can r-click Devices and interfaces ==> "create new" ==> "Simulated device" ==> USB ==> USB 6008. Apart from the device name (which can be changed), all code should function the same.
This is also very good to manually control and test things, like setting a DO, send a AO voltage and then read it back through a AI.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 13 of 13
(665 Views)
