How to acquire a series of position data in a while loop which generate a position once a time in labview?
My program is whole in a while loop. Once it runs, it will use kinect to keep acquire my head position data, so it will generate a position once a time. I want to attain 5 positions, and use it to calculate 3 velocity and 2 acceleration. How do I get 5 once while it generate 1 once time?
(2,743 Views)
Accepted by topic author 100148X
If your received data is brought to the edge of the while loop, and you right click where that wire exits the while loop, you can select "Enable Indexing" which will produce an array of the received data as big as the number of times through the loop. Alternatively, check the "Help:FInd Examples" for "Producer/Consumer", which will allow your receiving loop (producer) to get data and send it to a processing loop (consumer).
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(2,722 Views)
Thanks. I m using the producer consumer pattern. But what I get in consumer loop is still a real-time position value. So how to get 5 positions in consumer loop?
(2,694 Views)
And I have already tried 'flush queue' & 'get queue statues', and this 2 all give me empty array.
(2,689 Views)
You don't understand the concept here. In the producer loop you will transfer the current reading from the kinect to the consumer loop. All your data processing and analysis takes place in the consumer loop.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,678 Views)
Can you post the code you have created so that we can see where you are heading?
Putnam
LabVIEW Champion
(2,662 Views)
I have used the first way to solve the problem. Thanks!
(2,633 Views)
