How to bind a numberkey to certain front panel button?
I know how to bind certain actions like move left, up, down, move right to buttons. But what if I want to
bind numeric key "1" to a button... is it possible?
Thanks all, in advance!
(3,254 Views)
Hi JLuna,
use the event structure to detect keypress events.
In the event case check for the key "1" to trigger your "button" event…
(3,245 Views)
Do you have an example I could follow?? Because I currently use the "Key Binding Property" but only certain
keys can be used; F1, F2, Return, arrow up, down, left, right among others. But numeric keys are not included in these properties...
Thanks!!
(3,240 Views)
Accepted by JLuna
Hi JLuna,
use the event structure to capture key press events:
German LabVIEW: "Taste gedrückt" = key pressed, "Zeichen" = char, "VTaste" = VKey
(3,231 Views)
Vielen Dank!
Ich spreche nur bisschen Deutsche.
Many thanks for the example! I also found out this example;
http://digital.ni.com/public.nsf/allkb/D295B048D1B6E0D3862571EA005FBDE4
But yours seems to be a bit easier 🙂
(3,226 Views)
