How to stop audio playing
Hi guys,
To simplify, I play an audio file when I click on the Play audio button.
Now when I click on the Stop Audio button, I want the audio that's playing to stop.
How do I do it please?
(1,124 Views)
Try using the low-level API. See the examples at the bottom page of Sound Output Configure VI
Control Lead | Intelline Inc
(1,083 Views)
R-click the Express VI and Show front panel, convert it to a normal VI, go into the new sub-vi to see what code is actually run. What you need is to get that task and end it before hand. (i.e. use some low level vi's as mentioned)
Qestit Systems
Certified-LabVIEW-Developer
(1,049 Views)
you may look at
"C:\Program Files\National Instruments\LabVIEW xxxx\examples\Graphics and Sound\Sound\Sound Player.vi"
(1,020 Views)
Accepted by topic author Ngouda
@alexderjuengere wrote:
you may look at
you then want to build around this e.g.
Spoiler
(1,010 Views)
Hi @ZYOng, @Yamaeda, @alexderjuengere
Thanks you all for your reply, that works now 🙂
Sincerly
(976 Views)
