09-22-2011 11:42 AM
I'm developing a simple program (using LV10) for my undergraduate students to demonstrate some concepts. However, the interface doesn't look too good to play with. I'm looking for some ideas to make it more attractive. Any suggestions would be greatly appreciated.
09-22-2011 12:12 PM
What is it supposed to do? As it stands right now what are the functions for the controls?
09-22-2011 12:19 PM - last edited on 03-28-2024 09:18 AM by Content Cleaner
If you are looking to make your user interface more attractive, check the following link: UI Interest Group . You will need to download the files and add them to your Front Panel Controls Menus.
Kudos/mark as solution are welcome! 😉
-Ciao
09-22-2011 12:28 PM
The left and bottom vectors and matrices are inputs. The start buttons at the top are used to perform different simulations. The results are shown at the output figures and tables. The timer is used to change the simulation time. And the picture frame is for a static picture.
09-22-2011 12:30 PM
Thanks P.Sanders for the useful link. I'm sure it would help.
09-22-2011 10:45 PM - last edited on 03-28-2024 09:18 AM by Content Cleaner
Use System controls for better visual display. You can customize controls to make front panel more attractive.
Use following control themes readily available.
UI Control Suite: Metallic Theme
09-23-2011 08:10 AM
We should make a distinction between making something look "pretty" as opposed to making something be more functional, as in easier to use and more efficient. Just because something has nice colors doesn't mean it's easy to use or the most efficient control to use. That's why I think we should also consider the functionality of the controls and how the front panel is to be used. For example, in the shown front panel:
09-23-2011 11:16 AM - edited 09-23-2011 11:16 AM
I agree with smercurio_fc. LOL @ millenia! 😄
09-23-2011 11:28 AM
Thanks PBP for the links.
Thank you smercurio for the comments. However my concern is how it looks rather than how it performs, where slow performance is not a concern. I included all the inputs and outputs in the same page (all the arrays and figures), so that the users may see the impact of changing inputs on outputs in real-time. The tab is for extensions. The time scale is for hours, however I think it's off the topic.
