Is it possible to add some offset on the Y-Scale of a graph when autoscale mode is enabled.
Hi All,
I am plotting  on a waveform graph with autoscale mode enabled. I want to have some offset on the upper and lower side of the Y-Scale. Is there any way of implementing this.
Thanks in advance,
Cooldude
(2,560 Views)
Accepted by Flamboyant
The only way that came to my mind is to do the autoscale by your own:
-Find the min and max (ready vi for that)
-Add a percentage of the range to min and max
-Optional coerce the new min,max accordingly to a round number (depending on log(range) )
-Set Scale with properties
Another way:
Add a plot with same data (or only the min and max point) with tranparent colour and multiply that data with 1.xx (xx percentage additional range)
Message Edited by Henrik Volkers on 09-18-2009 12:40 PM
Greetings from Germany
Henrik
LV since v3.1
(2,558 Views)
