Is it possible to display user defined class properties as a hierarchy
So I drop down a property node and right click to see a list of all possible properties.  They are nicely organized in groups and subgroups etc..
Is it possible to do the same for properties I define for a class?  Let's say I have 20 properties to access data members.  Some of them are related to each other in some way so I want to group them on the property drop down menu.
Randall Pursley
Message 1 of 8
(4,320 Views)
Accepted by rpursley8
I have never tried this, but try giving the properties names like "group 1:property 1", and "group 1:property 2". LabVIEW uses that sort of syntax in several other places...
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 8
(4,289 Views)
The smiley faces should be a colon followed by a "p".
Mike...
LabVIEW Champion
Message 3 of 8
(4,281 Views)
Mike's suggestion of using the colon should work. I don't remember the details, but look at the help page for the class properties dialog where you can specify the long/short/localized name. It should be there.
___________________
Try to take over the world!
Message 4 of 8
(4,262 Views)
That seems to work.  The colon part.  The p is not needed
Randall Pursley
Message 5 of 8
(4,237 Views)
The p was only because in my example the names were to be "property 1" and "property 2". The bigger point is that LabVIEW tends to do things in the same way in many places. Colons are used to create hierarchical menus in XControls and polymorphic VI names, so I figured give it a try -- it might work here too.
Over the years I have discovered a bunch on neat features in this way.
Mike...
LabVIEW Champion
Message 6 of 8
(4,209 Views)
Should this still work?
I've just tried it in 2017 SP1, but it won't let me use colons in the property folder name.
E.g.
Group:Property
Foo:Bar
Using LV2018 32 bit
Highly recommended open source screen capture software (useful for bug reports).
https://getsharex.com/
Message 7 of 8
(3,438 Views)
Aha, it's the Localized Long Name that needs to be modified, not the actual Property folder in the Project Folder:
ResultResult
Using LV2018 32 bit
Message 8 of 8
(3,425 Views)
