Is there Modbus custom device for LINUX RT target CRIO-9049
is there Modbus custom device for LINUX RT target CRIO-9049
(340 Views)
I've never used either but there does appear to be two options in the old NIVeriStandAdd-Ons GitHub.
https://github.com/NIVeriStandAdd-Ons/Modbus-Custom-Device
https://github.com/NIVeriStandAdd-Ons/Modbus-Custom-Device-v2
At the very least they may be good starting points for you.
(302 Views)
v2 works. I have been using that on cRIO-9038 in VeriStand 2021.
(285 Views)
Modbus packed library(Modbus API.lvlibp) is not getting loaded due to version mismatch in the V2.
How to get the packed library compatible with labview 2023
I am using Labview 2023 Q3,veristand 2023
(261 Views)
Accepted by topic author AnveshKP
You can ignore the loading error.
  1. Build both the Packed Library specification under Modbus-Custom-Device-v2\Modbus-Custom-Device-PPL\Source\Modbus PPL.lvproj
  2. Then build Configuration Release and Engine Release of the custom device source.
(226 Views)
