Is there Modbus custom device for LINUX RT target CRIO-9049
is there Modbus custom device for LINUX RT target CRIO-9049
(255 Views)
I've never used either but there does appear to be two options in the old NIVeriStandAdd-Ons GitHub.
https://github.com/NIVeriStandAdd-Ons/Modbus-Custom-Device
https://github.com/NIVeriStandAdd-Ons/Modbus-Custom-Device-v2
At the very least they may be good starting points for you.
(217 Views)
v2 works. I have been using that on cRIO-9038 in VeriStand 2021.
Control Lead | Intelline Inc
(200 Views)
Modbus packed library(Modbus API.lvlibp) is not getting loaded due to version mismatch in the V2.
How to get the packed library compatible with labview 2023
I am using Labview 2023 Q3,veristand 2023
(176 Views)
Accepted by AnveshKP
You can ignore the loading error.
  1. Build both the Packed Library specification under Modbus-Custom-Device-v2\Modbus-Custom-Device-PPL\Source\Modbus PPL.lvproj
  2. Then build Configuration Release and Engine Release of the custom device source.
(141 Views)
