Is there an easy way to change the stacking order of controls on the front panel
I have two controls. I would like to place the smaller one over the larger one. Is there an easy way to change the stacking order?
Thank you,
Chuck
(2,479 Views)
Accepted by chuck72352
On the top of your LabVIEW front panel, there should be a button that looks like two arrows going in a circle.
Select the large control then press 'send to back'
Cory K
(2,476 Views)
