Issues with implementing a 32 resp. 64-bit dll to LabView 2013 13.0f2
Sorry for my late answer, but I had to do a practical lab course during the last weeks.
I tried to get used to C by working through a tutorial. I will test if my new "skills" helped and will post the new VI as soon as possible.
Thank you very much for your help!
Message 11 of 15
(848 Views)
As the ReadPositionFunction did not work after many tries, I wanted to test a even simpler and more basic function, the "FindDevices"-Function.
I used the Dll-Wizard to create an appropriate VI. The problem is even this VI does not work and constantly gives Error 1097.
Although I think that a number of type "long" in C means that it has 4 bytes or 32 bits, I tried out to change representation of "DeviceCount"  in every way from 8-bit-unsigned to 64-bit signed. I also changed the Calling convention to WINAPI, only to see if that is the problem. But it did not help. Next (just to try out), I changed the "Pass Type" from "Pointer to Value" to "Value", even if the header implies that the function refers to a pointer (if I got the "&" right).
So what can I do now, to get this most basic VI to work?
To be sure that the VI is not broken, I also tried the "SelectDevices"-Function. In this case, I don't get any error message. However, I am not sure ,how the function return is supposed to return "True" if it is a 32-bit integer, but a string did not change the result either.
PS: Is there maybe any option to include a working .exe in LV? 😉
Message 12 of 15
(804 Views)
I only have LabVIEW 2011 on this computer so can't look at it for the the moment. Those functions are all a bit troublesome since they use the C++ reference parameter syntax, which by all compilers I know of should be simply implemented as pointer parameter but there is no guarantee for that.
However, a first trial would be a Call Library Function Node with one parameter.
return value: int32
1st parameter: int32 passed as pointer to value
if this still gives you an error 1097 the only other thing I can think of would be to try and change the calling convention. If neither of these helps then the function is not callable through the Call Library Node.
A boolean is indeed just true and false but depending on the definition is always at least a byte. The C++ bool is generally implemented as byte where the value 0 is false and anything else is true, but C/C++ explicitedly does not define the exact size of its datatypes but leaves that decision to the compiler builder. The WinAPI BOOL is a 32 bit integer with the same semantics. Other APIs can define their own boolean definition which can be anything that the underlying C compiler can implement as addressable identity (meaning for almost all modern CPU architectures it needs to be at least a single byte or more. Some CPU architectures for instance have a performance penalty for byte accesses that are not aligned to their natural register size).
Rolf Kalbermatter
My Blog
Message 13 of 15
(795 Views)
My present VI uses
Return Value: Int 32
1st Parameter: Int 32, passed as pointer to value  (both Types are "numeric")
I tried to use first "C" and then "stdcall(WINAPI)" as Calling convention, but i got the error 1097.
Message 14 of 15
(783 Views)
Accepted by topic author MrKSE
So finally I implemented the device in LabView.
I used the trinamic motor control language via VISA Write/Read. I did not know that this motor used that language, but in the end the vendor told me.
Thank you for your help!
Message 15 of 15
(745 Views)
