01-30-2007 03:59 PM
01-31-2007 10:00 AM
Can you be more specific about which example you are porting to CompactRIO? Where did you find this example? Is this from LabVIEW 7.x?
Moving from LabVIEW 7.x to 8.0, there were some very significant changes in how you configure the project to interact with the FPGA. In LabVIEW 7.x the project was only used to configure the FPGA and develop FPGA VIs. In LabVIEW 8.x the project is a completely different structure and is used for all LabVIEW targets (FPGA, RT and Windows, as well as others).
LabVIEW does include a tool to move FPGA applications from LabVIEW 7.x to 8.0. It is found under Tools >> FPGA Module >> Import FPGA Files from LabVIEW FPGA Module 1.x.
After running this tool you will likely still have to make a few manual changes in the newly created project to get everything to run correctly.
02-01-2007 03:42 PM
02-15-2007 05:25 AM
Hello fpga.be,
Could you tell what is wrong with your program? But there is one thing you NEED to do, to make this example work on your cRIO, it's compiling this example on your cRIO to have a valid reference on the VI FPGA_Arb_Open_Ref.vi. Or not, your application will not run correctly.
Are you receiving an specific error message?
09-18-2007 07:36 AM
09-19-2007 10:28 AM
Hi fpga.be,
I didn't find the VI you mentionned above but a similar. I include it in the project and in the ZIP attached below.
One think I need to mention to! Don't forget that you need to download the *.LVM file on the FPGA itself because you are working on a remote target! So you need to reference to a file on the cRIO.
Also don't forget to recompile the VI for your cRIO system !!! It's very important.
Best Regards,
10-28-2009 02:04 PM
Hello I am trying to get this example to work in LabVIEW 8.5 / LabVIEW FPGA with my Intelligent DAQ 7831-R PCI card. Is there an example already done that will work with this?
The FPGA portion compiles fine, but the Host has a ton of errors, (functions in the subVI's not compatible with my board). I could spend a bunch of time weeding out code I don't need, but I wanted to check here first to see if there was something already done?
http://zone.ni.com/devzone/cda/epd/p/id/447
(Link with the code I am using)
Filename: arb_wavegen_lv821.zip
Project file that I am trying to work with.
-thanks!
11-10-2009 06:42 AM
Hi
As far as I know there is no ready made example for the R-series cards. The reason the example runs into errors probably has to do mainly with the reading of the calibration constants etc, which are not available on your R-series card. So probably you will have to modify the example yourself, or build a new one based on the same principles. In this case the following link will be quite interesting, as it describes the procedures being used in the example step by step:
http://zone.ni.com/devzone/cda/tut/p/id/3027
Kind Regards
