Labview Code Generation Failed to execute
I get this error when I try to obtain data with MyDaq, I am using the latest version of labview, I already tried uninstalling labview and the problem is not solved, I would like to know if you can help me.
Message 1 of 13
(7,311 Views)
Attach the VI at generates this error.  It would also help to say precisely what version of LabVIEW you are using.  Please note that not too readers of this Forum have installed LabVIEW 2022 Q3 (or whatever is the new designation) ...
Message 2 of 13
(7,266 Views)
Message 3 of 13
(7,233 Views)
Could be something corrupt in "<vilib>\express\DAQmx\DAQAssistantConfig\ConfigVIs.llb\Configure DAQmx Assistant.vi"
Could be something corrupt in "C:\ ... \National Instruments\MAX\Assistants\DAQ Assistant\common\supportFiles\ExpressVIsxxx.llb\"
Could be an improper installation of LV or NI-MAX.
Message 4 of 13
(7,212 Views)
Running 2022 Q3 (just installed) and get the same response when pulling in DAQ Assistant.  Please update if resolved.  Pinging tech support...will do the same.
Message 5 of 13
(7,188 Views)
For anyone new with the same issue on LV2022 Q3, this is a known issue documented here - https://www.ni.com/en-us/support/documentation/bugs/22/labview-2022-q3-known-issues.html
To resolve the issue, in addition to LV2022 you just have to install LV2021 SP1 (no need to activate)
Santhosh
Soliton Technologies
Message 6 of 13
(7,176 Views)
Many thanks.
Message 7 of 13
(7,169 Views)
@JJFSS wrote:
Many thanks.
You can give a kudo to say thanks...
Message 8 of 13
(7,156 Views)
I wasn't able to downloaderror2.PNG the 2021 SP1 version even though i have license for 2022Q3
Message 9 of 13
(6,938 Views)
You need to login, then try to download
Message 10 of 13
(6,928 Views)
