Listbox with image
Hello dear all,
I would like to make a language listbox with images as shown in the figure below.
Is it possible to do it?
Can you please show me?
Thanks in advance
Message 1 of 13
(2,454 Views)
Right-click the listbox; select Visible Items -> Symbols
Create an invoke node; select Custom Item Symbols ...
Message 2 of 13
(2,436 Views)
You can apparently show the symbols and set custom images for the symbols. (details). I have not tried this myself.
Message 3 of 13
(2,433 Views)
Hi Paul-Cardinale,
I tried to follow what you told me but I can't.
Can you show me just the first item and I can continue please?
Message 4 of 13
(2,414 Views)
Hi altenbach,
I'm looking at the details but I haven't read them yet, I didn't understand everything.
Message 5 of 13
(2,413 Views)
Accepted by Ngouda
Here
Message 6 of 13
(2,380 Views)
Accepted by Ngouda
Also note that the images will be scaled down to 16x16 pixels, so your flags are not really suitable for this.
(You could implement the entire thing as a big 2D picture, but that would require quite a bit of backend code to format the list and parse e.g. mouse clicks and such)
Message 7 of 13
(2,373 Views)
Scaling down his image so the flags fit in 16x16, looks like this:
Might get a better result starting with larger flags.
Message 8 of 13
(2,350 Views)
Accepted by Ngouda
Yes, my experience is it looks nicer when you use 32x32 Px images, they are nicely scaled down.
P.S. As a hint, the index at the "index" input (in the link provided by altenbach) corresponds to the symbol ring constant in the Dialog & User interface palette. If you don't want to interfere with these built in symbols, use an index greater 42.
Greets, Dave
Message 9 of 13
(2,316 Views)
Good morning Paul_cardinale,
Thanks you for your answer
Have a good day
Message 10 of 13
(2,309 Views)
