Listbox with image
Good morning altenbach,
Thank you for your answer, I tried it.
Have a good day
Message 11 of 13
(589 Views)
Good morning daveTW,
Thank your for your answer, yes I tried all your answer.
Have a good day
Message 12 of 13
(589 Views)
There are methods of getting larger glyphs with some hackery.  If you want larger icons you can also vote with a kudo for this Idea.
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Support-Larger-Glyphs-in-Listboxes-and-Trees/idi-p/38...
In that is also a link to the discussion where the work around is given.
https://forums.ni.com/t5/LabVIEW/Large-symbols-for-Multicolumn-Listbox/m-p/1239374#M524477
This work around is fine if you aren't doing resizing, scrolling, or inserting, and copying rows.  Then more work is needed to have it work properly.
Message 13 of 13
(497 Views)
