Logging key strokes
I actually started using that at first, but it wouldn't save correctly for some reason.  I figure I can work on that again and see what I can come up with.  May have to do multiple case structure.  I'll keep you all posted.
meanwhile, if anyone know how to accomplish the task using the previous method, add to this post.
guilio_2008
Message 11 of 13
(972 Views)
You would need to post your code if you can't save. I don't see where multiple case structures would be used.
Message 12 of 13
(958 Views)
I remember now why I did go that route.  When I would press one key, since the loop ran so fast, you would get repeats of the same value.  If you slow the loop down, then you may not get what everyone was typing since people type at different rates.  Let me get something together and post it to show what I mean.
The even structure is really nice.  Does repeats, can easily delete last character if you made a mistake and it's adaptable to anyones type speed.
Thanks for you help,
guilio
Message 13 of 13
(955 Views)
