MKS PR4000 CONTROLLER driver for labview 8.6
Hmm, I cannot really give further advice, this becoming more like a hacking 😄
Is this a hobby project? You could try to sell these hardware elements on ebay, and buy a second hand flow controller which you just plug&play together with the PR4000 controller...
Message 51 of 80
(1,755 Views)
Hehe , I suppose I'll have to buy a new MFC.  Thank's for all the support.
Message 52 of 80
(1,747 Views)
Blokk!
Would you mind saving and posting for labview 12 as well? I really appreciate it! Thanks very much!
Message 53 of 80
(1,680 Views)
attached
(you need to put also the official PR4000 driver under the instr.lib, or install via the drivers menu of LV)
Message 54 of 80
(1,671 Views)
Hey SVP1,
I wonder if you could help me figure out how to get the unit into REMOTE mode. I don't see "RT" anywhere in the manual meno on the unit itself. Do you have a vi that has the proper syntax to send this command? I'm running the exact same vi's as you with the proper parity, and not getting any communication. The remote light on the unit is dark.
Any help would be appreciated! thanks
Message 55 of 80
(1,656 Views)
Hi,  try to enable remote mode by pressing by yourself the button on the controller panel. I do not set the controller in remote mode through LabView.
Message 56 of 80
(1,644 Views)
Hi, can someone clarify on how to turn the remote mode on on the unit itself? I do not see it anywhere in the manual. I'm using a single channel PR4000.
Message 57 of 80
(1,592 Views)
I use a 2 channel PR4000. I do not need to enable remote mode manually, I just connect the RS232 cable and use the LabVIEW functions from the library I attached above...
Message 58 of 80
(1,589 Views)
Hello friends,Does MKS PR4000 to control automatically gas flow on MFC with a Baratron or reads gas flow only?
Message 59 of 80
(1,557 Views)
What you write does not make sense. An MFC does not need and does not have a baratron. Baratrons are for pressure measurement. You can connect mass flow meters (only flow measurement), mass flow controllers (measurement and control), and pressure sensors.
Message 60 of 80
(1,552 Views)
