01-25-2016 03:54 PM
01-25-2016 04:03 PM
01-25-2016 06:47 PM
hello
an ordiniary DAQ for example NI USB 6008 DAQ.
here is a schematic similar to my expected work.
01-25-2016 07:03 PM
I will use pressure regulator after N2 cylinder and befor MFC. like the picture here.
in my e nose system I will need to read some gas sensors and control some electronic (solenoid) valves. I will do this using a DAQ( for example NI USB 6008 DAQ) and LabView. The sole problem here is to add a MFC to this system and to maintain Flow rate on 1000 sccm during the tests.
I need a MFC that I can controll it using my DAQ and also be able to monitor it on the same labview user interface that will be for the whole e nose system.
what should I do exactly? 😞
01-25-2016 09:03 PM
01-25-2016 11:55 PM
Try to buy a mfc which is controllable by analogue signals. An example:
See page 1-2 for a Analog I/O port pinout, a D-sub port with 9 pins:
use pins 3-4 to supply DC voltage between +13.5 and +27 Volts so you power the mfc,
use pins 6-8 to vary the mfc setpoint with a DC voltage signal (analog output on USB-6008, 0-5V),
use pins 2-7 to read the actual flow, between 0-5 V voltage signal full scale (5V = maximum specified flow).
01-26-2016 04:26 AM
Thanks for the answers
Buying that MFC was a mistake and waste of time and money.Also that was the cheapest one (100 $).
I wish I could control that MFC but it seems expensive and time consuming. So I should buy another MFC. But if there is any other way to control this MFC using LabView and a NI USB 6008 DAQ please tell me. Here is my MFC:
If there is no way, so which type of MFC should I buy?
9 pin or 15 pin?
01-26-2016 04:33 AM - edited 01-26-2016 04:41 AM
I beleive, there is no way to control a DEvicenet interface using a DAQ USB-6008.
"If there is no way, so which type of MFC should I buy?
9 pin or 15 pin?"
Both should be ok (you will just need a different D-sub socket to make or buy), but be sure and double check the manual before you buy. You need a MFC which can be controlled using 0-5 V voltage signal, and creates an analogue output proportional to the actual flow rate (between 0 and 5 V DC).
The best if you post here the model which you find, so we can have a look.
Do not forget, you will also need a proper power supply with DC voltage inside the required range specified in the MFC's manual. Also be very careful when you do the wiring, you can damage your MFC if something wired incorrectly.
EDIT: another option which you can consider is buying a MFC with RS232 interface. Many MFC has RS232 pins beside the analogue control/read option. Either you have RS232 (also called "serial port" often) already in your PC, or you can buy cheap USB-RS232 converters (few EURs, try to get models with FTDI chip, usually they work good with LabVIEW). If you get an MFC with RS232 interface, you even do not need the USB-6008 to use. You simply use RS232 communication between the PC and the MFC. Many MFC models have LabVIEW drivers available for RS232, but even if not, using the manual, you can figure out the serial commands which you need to program in LabVIEW...
But still, you will need a power supply (PSU).
01-26-2016 06:44 AM
I bought few MFC for 20-40USD Tylan. I control them with 5VDC and use USB 6009 just to monitor them. Read all posts carefully. Try to find on ebay cheap MFC with card edge 20pin. The normal price is less than $50.
01-26-2016 01:00 PM
thanks for the answers specially for Blokk's explanations.
my goal is to maintain 1000 sccm flow rate. What is the mentioned sccm on the MFCs? Is it the final range?
So should I buy a 2000 sccm MFC and control it for example using a 2.5 volt, or a 1000 sccm MFC control it using 5 volt?
What will be the correct connections and piping? should I use 2 valves beside the MFC like this?
an other important question: To what pressure should the N2 gas be reduced using a pressure regulator befor the MFC?
