Matrix
If I have a matrix like the attached file (1.csv),
I want to divide each element by a certain number for example 4 and generate a new matrix to be like the attached file (2.csv).
I make code like the attached. But I see it not practical if I  want to change the element (Numeric) and with the large matrixes.
Do you have any ideas!
(1,805 Views)
Accepted by BaJa_2020
(1,794 Views)
Some comments about your code:
  • You have a 2D array, not a matrix. (In LabVIEW, a matrix is a special datatype designed for linear algebra).
  • If your inputs are integers and divisible by the numeric, there should NOT be any orange. It should be all blue! Try it!
  • "Index array" is resizeable. You don't need 13 instances!
  • There is no reason for your local variable!
  • If you can describe the problem in one paragraph, something is wrong if it takes a screenful of code. Look at my solution above.
  • Not sure why you have a selectable path, but a hardwired file name. Seems too rigid.
  • Code needs to be scalable. My example works for any size inputs and values. Your code would be impossible to scale to an input with much larger arrays.
  • I recommend you look at some basic tutorial about array operations.
  • Good luck!
(1,777 Views)
Thank you, I will follow your advice.
another inquiry:
I I am going to make some calculation for the output array. Then I would like to back it to the original dimensions.
I should collect every 4 (element) together.
in another way.. dose it possible to reverse this code?
(1,742 Views)
That depends on the calculations. Are all sets of four rows still identical after the calculation?
(1,737 Views)
Here's one possibility:
(1,734 Views)
