NI Package manager installation fails with error -125813
Recently one of the user laptop throws error -125813 while installing NI package manager as part of an deployable LabVIEW application. The same happens when installing NI package manager separately as well. I have ensured that there are no NI software in control panel before retry. The same works in another laptop.
Error message:
The 'NI Package Manager Installer Wrapper' installation has failed with return code -125813.
OS: Windows 11
Does anyone encountered the same and found the solution?
(363 Views)
Jlakshmi -
I think the error message associated with this error is:
  • "The following packages must be removed before completing the current operation: {0}".
If you share the following files with the forum, someone might be able to gather more details as to the underlying cause:
  • %localappdata%\National Instruments\NI Package Manager\Logs\errorlog.txt
  • %localappdata%\National Instruments\NI Package Manager\Logs\NIPkgLogs\NIPkgLog_*.txt
Scott Richardson
https://testeract.com
(329 Views)
Attached both error files. Some more background on the problem. While trying to resolve the problem user has installed both NI package manager 18.5 and the latest version. I was able to remove the latest version. But 18.5 version is not available in program list or app list. I could see that is being available inside program files.
(296 Views)
Accepted by topic author Jlakshmi
I have temporarily resolved the problem by renaming NI package manager 18.5 version. Post that latest version of package manager worked and then resolved further problems by repair.
(291 Views)
