07-23-2024 07:35 AM
Recently one of the user laptop throws error -125813 while installing NI package manager as part of an deployable LabVIEW application. The same happens when installing NI package manager separately as well. I have ensured that there are no NI software in control panel before retry. The same works in another laptop.
Error message:
The 'NI Package Manager Installer Wrapper' installation has failed with return code -125813.
OS: Windows 11
Does anyone encountered the same and found the solution?
07-23-2024 06:30 PM - edited 07-23-2024 06:32 PM
I think the error message associated with this error is:
If you share the following files with the forum, someone might be able to gather more details as to the underlying cause:
07-25-2024 02:23 AM
Attached both error files. Some more background on the problem. While trying to resolve the problem user has installed both NI package manager 18.5 and the latest version. I was able to remove the latest version. But 18.5 version is not available in program list or app list. I could see that is being available inside program files.
07-25-2024 07:06 AM
I have temporarily resolved the problem by renaming NI package manager 18.5 version. Post that latest version of package manager worked and then resolved further problems by repair.
