Output frequency is different then the set value
I am generating sine wave using "simulate signal" block and sending it to DAQ Assistant to excite a shaker. The settings of Simulate signal and DAQ assistant are shown and the VI is also attached. The frequency being sent to DAQ is same. BUt when I am measuring the output frequency of shakr it is always coming higher. I am using BNC NI 9260 card and the shaker is a pssive device.
Can someone please guide where the problem is?
Thanks and regards
Message 1 of 14
(4,736 Views)
Thanks and regards
Message 2 of 14
(4,743 Views)
How do you know that the shaker is at a higher frequency?
Message 3 of 14
(4,720 Views)
I am measuring it using a laser displacemnet sensor and getting voltage through Labview in another computer
Message 4 of 14
(4,715 Views)
The frequency (samples/second) of the output signal have to match the speed of the hardware device output update rate. Check to see if you can verify the two match-up.
Ben
Message 5 of 14
(4,686 Views)
How much off is your measured frequency (in %, ppm or Hz) and is the error within the accuracy of your interferometer and/or DAQ board?
... and why is your DAQ Assistant configured to generate 1001 sample blocks?
Message 6 of 14
(4,638 Views)
Accepted by MAnees
Looking at the datasheet you will find:
So, if you create samples for a different samplerate, not supported by the device, the resulting frequency will differ 🙂
Your example uses 1k SPS , and I don't know how the driver will coerce this.
Look for the examples, I bet there is a vi 😉
Finally, you will always find some differences between the frequencies, because the two units you use (one for generating, another to measure) don't share the same clock.
Greetings from Germany
Henrik
LV since v3.1
Message 7 of 14
(4,635 Views)
My frequency is approx 1.61 times higher and the error is almost negligible. i just kept one sample extra to write to start the new wave with 1st point of new cycle however i m not sure about this.
Message 8 of 14
(4,602 Views)
Accepted by MAnees
As Henrik Volkers pointed out earlier your module can only sample at specific rates and as stated on Henrik's datasheet screenshot, the lowest rate is 51200 / 31 ~= 1.652 kS/s. That is why it is running ~1.65 times too fast.
To generate a theoretically perfect 1 Hz you either need to generate (and repeat) 31 periods of signal using 51200 samples or probably easier, 1 period of 51200 samples but change your rate (on both your Create Signal and your DAQ Assistent) to 51.2 kS/s
Message 9 of 14
(4,596 Views)
Accepted by MAnees
According to the spec the lowers possible samplefrequency is 1.652 kHz , your output is a distorted sinewave with 1001 points...(assumed, I can't open your vi ) ...  so I would expect 1.6503 kHz ... almost fits 😄
How do you measure the frequency?
Try it with a samplerate of 1652 Hz and generate 1652 sample 😉
(for 1Hz, if you need to generate 0.8Hz you need to recalc the number of samples 😉 )
EDIT: LocalDSP... beat me with 5min 😉
MAness: You should really learn some basics on digital signal processing. The hint with a higher samplerate is a good one!
Henrik
LV since v3.1
Message 10 of 14
(4,595 Views)
