Output pulse train on DIO
Hello all,
I am in the unfortunate situation where I have to generate a pulse train on a single, non-counter DIO channel.  The controller is a PXI RT controller.  Is there a way to generate a pulse train without using a counter and without flipping bits in software?
cirrus
(2,764 Views)
Accepted by cirrusio
Hi Matt,
you either use a counter output - or you have to flip bits on your own!
Or you use some external hardware to generate a pulse train. There are simple schematics possible with a classic 555…
(2,748 Views)
Yup...thought that was the case.  Don't have the two options mentioned.  Customer  wired  into the wrong pfi and I am stuck with what I gots.  Thanks Gerd.
m
(2,733 Views)
