Polymorphic Object??
If Init.vi is unique to the child you will have to do something like this.
I've never tried it, but I assume you can replace the Parent constant with a child constant and avoid the second To More Specific.  Of course, this kind of defeats the purpose of OOP if you do that.
If Init.vi is dynamic dispatch, you will do something like this.
Note in this case that we are dynamically loading the child object onto a parent wire.  Because the actual type of the object is child, it will call hte child's Init implementation if it is provided.
Tim Elsey
Certified LabVIEW Architect
Message 21 of 45
(760 Views)
"in this case that we are dynamically loading the child object onto a parent wire"
Is this because of GetName?
Is Getname a method of the child, parent, or LV Object? If the later where do find it?
Message 22 of 45
(752 Views)
No, that's not why.  GetName is just a red herring that i was too lazy to correct.  GetName and GetColor should be taken as Write Visa and Read Visa in your images.  So to answer your question it is a method of the parent, which is also implemented as dynamic dispatch in the child class.
Dynamically loading the child onto the parent wire is done by virtue of providing the path to the child class to Get LVClass Default Value and the To More Specific with the parent object constant wired to it.
Tim Elsey
Message 23 of 45
(746 Views)
Hmm...so I'm back to where I started, kinda. When I wire from WriteVISA to Init it creates an error.
Parent has:
WriteVISA
ReadVISA
Child has:
WriteVISA(inherited, not implemented in child)
ReadVISA(inherited, not implemented in child)
Init.vi(with dynamic input/ouput nodes for object wire)
Message 24 of 45
(738 Views)
Parent has:
WriteVISA
ReadVISA
Child has:
As your project currently stands, the dynamic inputs on Init.vi don't matter at all  (it may if you add parent or child implementations in the future.)
All you need to do to get the error to go away is do like I did in the first picture of my previous post.   Here it is again.
Tim Elsey
Message 25 of 45
(734 Views)
Yes, that does work, except, this whole exercise is because the class in the filepath IS a child...I don't know which of the hundred he might be so the To Specific is not an option.
The goal is to have a folder full of children each representing a meter/power/supply/scope/etc, 10 today, 20 tomorrow, 30 different ones the day after. But only have a child .lvclass for each and have the main app load whatever is there.
What am I missing?
Message 26 of 45
(742 Views)
@MacDroid wrote:
What am I missing?
An Init implementation in your parent class.
Seriously though, if you provide all of the functions you will need in the parent class, any child class will fit right in directly.  That's the whole beauty of dynamic dispatching.  In this case your parent class will more or less serve as an abstract class.  Your parent class will be what is called a "fat class*" which means it has all of the VIs of its children even if it doesn't use them itself
*Not sure if there's a technical term for that, but that's what we called it in school
Tim Elsey
Message 27 of 45
(739 Views)
@MacDroid wrote:
Ok, so I'm missing something. In the above example the class spec'd in the class path is a child, with Init.vi, of Obj_Equipment. But the path between WriteVISA Name and Read VISA Name is apparently not a child.
How is you Wrte VISA Name.vi set up ? does it have dynamic dispatch connectors ?
Message 28 of 45
(732 Views)
That works if I know all the VI's the parent will ever need.
But it may change every time the avaialble equipment changes.
That's why I am trying to have the child only know about the differences.
Message 29 of 45
(723 Views)
If instruments come along in the future with new features you're going to have to edit the code regardless to add this functionality to the calling VIs.  Your main VI won't know anything about these new features even if your new class has them until you add them on the block diagram. While you're editing your main VI to handle these new features, go ahead and add them to the base class.
With any existing functionality you can populate your base class with any and all of the VIs that you will use.
Now, am I missing something?
Tim Elsey
Message 30 of 45
(710 Views)
