Powerflex 755 Communication
Here's a better screen shot
Message 11 of 14
(1,071 Views)
It has been about 2 year since I set up our Ametek Reflex Ethernet power supplies. So I went to check out our set up.
I did not set them up in MAX. and they do not show up in MAX.
At the moment the test sets are all running 72 hours test so I can't play around with the set up to try to duplicate your error.
But ...
Can you use either of the these to open a VISA ref to your device.
TCPIP0::<ip address>::inst0::INSTR
TCPIP0::<ip address>::<port>::SOCKET
Can you use the DOS tracert command to find your device?
tracert -d -h 2 -w 500  192.168.255.255
If you can, attached is the VI I use that uses Tracert to find my power supply and obtain an open ref to them to communicate with them.
Omar
Message 12 of 14
(1,062 Views)
Do you think I even need to use VISA?  What is the purpose of VISA?
I downloaded the Ethernet IP add on.  Maybe this add on is all I need.
Message 13 of 14
(1,043 Views)
Hello, I know this is five years late, but, I'm in need of a powerflex 755 driver, has any one had any success in developing one?
Message 14 of 14
(767 Views)
