Preparing a VI for a VFD
If by that you mean function codes that can read and rewrite control parameters that startup, stop, and set operating frequency of the VFD, then from what I understand, yes. As for the Visa Write function, would that be something I use for the TCP/IP VI I uploaded as well (after it has been adjusted for a serial connection, that is)?
Message 11 of 14
(1,008 Views)
I'm a little confused by that wording- I'm assuming you mean just remove all TCP/IP VIs and put in appropriate VISA serial VIs. Then you could add an event for changing the frequency of the VFD.
-Lauren
Message 12 of 14
(986 Views)
Yes, that is what I meant. Sorry for the confusion. And great. I think I know how to set up the VI now. Thank you, Lauren.
Message 13 of 14
(981 Views)
You're welcome! Best of luck with the project.
-Lauren
Message 14 of 14
(969 Views)
