Problem moving example to a different FPGA target
Hi all
I am trying to follow the following tutorial:
http://www.ni.com/tutorial/5075/en/
I am having some difficulties because when I try to follow step 2.1, and add the target, it says the target is already in the project. I have attached a screenshot.
As can be seen, the chassis in the project is a cRIO-9116, which was the chassis used in the example. The chassis I am trying to use in conjunction with the example, is the cRIO 9022. I followed the steps in the tutorial exactly but am getting this problem. Any suggestions?
(3,045 Views)
Hi David,
please read this LabVIEW-RT idea (and the comments for that idea)…
(3,037 Views)
Am I looking at the comment regarding changing the XML of the project? Or the subsequent links?
(3,019 Views)
Update, just tried the migration wizard but unfortunately it seems to only be available for LabVIEW 2010. So guess that isn't an option. Guess I'll have to mess about with the XML
(3,008 Views)
